2002 Dodge Neon FAULT CODE PO725
2002 DODGE NEON
97,000 MILES • 4 CYL • FWD • AUTOMATIC
GARY V
TEST DRIVE TRANS HANGS IN LIMPIN REPLACE INPUT AND OUTPUT SENSORS CLEARED FAULTS TRANS SHIFTED OK AFTER 5 MILES CHECK ENGINE LIGHT CAME BACK ON WITH FAULT CODE PO725 AND BATTERY LIGHT CAME ON DASH LIGHTS FLICKER AND BRAKE LIGHT FLASHES ON. STUCK CAN YOU HELP THANKS GARY
Dec 22, 2008 at 5:51 PM
ZACKMAN
  • 4,202 POSTS
Don't do anything to your transmission just yet. Fix the electrical problem first. Go to Autozone or CSK/O'Reilly and have your electrical system checked out. Battery light and brake light on is a telltale sign of bad alternator. But your belt is probably loose, that may cause the light to go off.
If your car doesn't have enough power, your transmission computer will go haywire and may prompt the CEL.
Dec 22, 2008 at 11:36 PM
