HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Dodge
Neon
Emission
EVAP
Leak
2002 Dodge Neon
BKRUMMEN
MEMBER
2002 DODGE NEON
2002 Dodge Neon
what does evap leak monitor large leak detected mean? Where do I start to fix this problem?
Sunday, September 21st, 2008 AT 12:35 AM
BMRFIXIT
MECHANIC
Check gas cap
check for fuel leak
check vacuum leak
check evap system hoses and line for leak
you may need to have a smoke test the system
good luck
need manual CHECK IT @
https://www.2carpros.com/kpages/auto_repair_manuals.htm
Tuesday, September 23rd, 2008 AT 8:55 PM
KFRY572
MEMBER
FOLLOW THE HOSE FROM MOTOR TO THE PURGE VALVE TO THE GAS TANK. IF YOU HAVE A LEAK IT IS BROKE SOME WHERE
Wednesday, October 1st, 2008 AT 7:32 PM
Please
login
or
register
to post a reply.
Related EVAP Leak Content
2002 Dodge Neon P0456 - Evap Leak Monitor Small (.020...
I Have That Error. How Do I Fix It. Where Do You Think The Leak Is? Thanks
Asked by
jal111
1 ANSWER
2002
DODGE NEON
GUIDE
EVAP Leak
Your car's EVAP system is designed to control fuel vapors which are naturally omitted from standing gasoline inside the fuel tank. These vapors are collected into the...
2001 Dodge Neon Evaporative Emissions System Leak
My Check Engine Light Came On And I Plugged An Obd-ii Reader Into It And It Said P0442 - Evap. Emissions System Leak: Very Small. Where Do...
Asked by
pdxneon
2001
DODGE NEON
Converter Is Plugged Cant Replace Right Away There Is...
Blocked Converter Getting No Power
Asked by
jmg429
1 ANSWER
2004
DODGE NEON
How Should I Go About Fixing This And What Do You...
My Girlfriend's Neon Has A Very Common Issue. She And I Are Driving Along And Out Of Nowhere, The Whole Intrument Panal Dies. Every Guage...
Asked by
Ryan2638
1 ANSWER
1996
DODGE NEON
1996 Dodge Neon I Can't Pass Emissions
My Neon Is Failing Emissions By 5x The Limit On Co And 2x The Limit On Hc. I Have Replaced The Evap Canister The Map Sensor The Iat Sensor...
Asked by
ccch510
1996
DODGE NEON
VIEW MORE
How to Read Codes Chevrolet
How to Clear a Check Engine?
Code Read Retrieval/Clear Scion
