My oil light comes on and dings at me when I drive for awhile. It stops when I speed up and starts when I come to a stop. Can you help me?
Friday, June 20th, 2008 AT 9:38 PM
LEGITIMATE007
MECHANIC
Yes more than likely your low on oil, I would have the oil changed and filled to the proper, level. If this doesnt solve your problem then Its more than likely your oil pressure sending unit. But adress this immediately, you don't want to keep driving with low oil, you can damage your car beyond repair.
SPONSORED LINKS
Friday, June 20th, 2008 AT 9:44 PM
ROSIESTOSIES
MEMBER
1 POST
I am having the same exact problem with my Neon. I have a 2000 with about 125000 miles on it. My oil is never low, so we are going to try and replace the sending unit and see if that works. I'll let you know if it does.
Saturday, June 21st, 2008 AT 1:10 AM
LEGITIMATE007
MECHANIC
This is to both of you guys, finally your problem could be, your oil pump. Lets hope not but it could be. So that I would go with
