2000 Dodge Neon fuel
61,000 MILES • 4 CYL • FWD • AUTOMATIC
TNATION
my car starts but will run for like 25 mins and then shuts off
can this be a fuel problem
is there a filter or a switch
Jan 23, 2009 at 9:01 PM
JDL
  • 16,098 POSTS
When the problem occurs, does it take awhile to restart? If it does, you can do some of the basic tests. Have a helper crank it while you check for spark at the plugs. If you have spark everywhere, check fuel pressure.
Can you check for codes? Some of the national brand autostores will check codes for free.
Jan 24, 2009 at 4:23 AM
