1999 Dodge Neon car will not go into gear
JILLCCOATES
  • 1999 DODGE NEON
  • 4 CYL
  • 10,000 MILES
Just put in different motor in my 1999 Dodge Neon and now it doesn't want to go into gear. The linkage is ok. Do you have any suggestion. Could the front pump be my problem. Fluid is good.
Sunday, January 27th, 2008 AT 12:50 PM
BMRFIXIT
  • 19,053 POSTS
Is it stuck in park or you put it in drive and it don’t move
if stuck in drive check the brake light switch
if no drive check your work again check the axles and check the torque converter and bolts
Wednesday, January 30th, 2008 AT 9:31 PM
Related General Content
