1998 Plymouth Neon
DACIAO
  • 1998 DODGE NEON
My car has about 130,000 miles. It gets overheated after running about 30-45 minutes. Do these cars have a sensor that controls the temp that may need to be replaced?
Tuesday, April 18th, 2006 AT 1:41 PM
JDL
  • 16,098 POSTS
Sorry for the late reply.
How hot is it getting in degrees F? Does the radiator fan work? Can you check applicable trouble codes?
Some commonly replaced parts for overheating, thermostat--water pump maybe even serpentine belt.
There is a coolant temp sensor on your vehicle, but, unless there is a code or something that points in that direction, that sensor isn't my first thought. The sensor is located rear of engine close to cam sensor.
I realize this is an old post. You probably don't even own this vehicle anymore. In the future hopefully you won't have any vehicle issues, but, if you do keep the site in mind. The site has more moderators than it used to. It's free.
Have a good day.
Sunday, March 22nd, 2015 AT 9:48 AM
