shifter won't go into park or low gear,can be put in reverse,neutral and drive and can be driven.
Apr 5, 2009 at 6:13 PM
CARADIODOC
CERTIFIED EXPERT
Look for the shifter cable's casing moving on the transmission or under the dash. A loose mounting bolt will let the casing slide instead of making the cable push and pull the shift lever.
