1995 Dodge Neon pcm programming
1995 DODGE NEON
142,000 MILES • 4 CYL • FWD • AUTOMATIC
XERXIES
  • 10 POSTS
i was wondering since my 95 neon has the pcm turn he alarm or should i say door chime on to notifie me when the engine overheats, can i get it programed to chime when the fuel is low?
thanks everyone who responds
Apr 3, 2008 at 9:00 PM
TONYBRAVADA
  • 12 POSTS
It should be possible, though I don't know how easy if it doesn't already ding. Does the light come on for low fuel? If not it could be a relay problem. Otherwise, you'd have to find someone who can program the ecu and more likely get a new one. There were a lot of changes from the 95 but the 98 I own dings on low fuel...
You can also try resetting the ECU by pulling the fuel pump fuse for about 1-2 minutes and replacing it (technically 45seconds but wait longer to be sure.) You can also disconnect the battery but this can take 10+ mins and I'd suggest 15-20 to be safe.
Apr 5, 2008 at 6:23 AM
