1995 Dodge Neon Engine start at times
71,562 MILES • 4 CYL • FWD • AUTOMATIC
OSWALD JACKSON
Trying to help my friend son. Car start sometimes run for a min or two then stop will not start back untill when you turn the ignition key on and the battery indecator light fllash on then it will start then stop like discribe above. This is what i have checked, i have tried to scan with snap on scanner not comunicating with pcm. check eng groud on or around trans. I only notice ground from bat to eng block. I am not sure if there should not be a ground wire to bell housing bolt or some place on trans. I notice it has a used trans. Second thing I notice the starter relay is missing and a wire has been run from bat to a added starter switch (push type mounted inside under steering columb) then wire from new switch to the connector where relay has been removed for starter. Thirdly it had some kind of sterio system that needed the direct wire from bat which was taken out and a added alarm system which was also removed. I have checked for power from ign switch to starter relay with switch in start position and there is none. I am trying to give as imfo as posible. The kid just both the car.
Nov 29, 2008 at 2:55 AM
LERVIN
  • 15 POSTS
This sounds like a wiring nightmare but I will attempt to help you. The top three things I would do and in no particular order are - Purchase a repair manual for this vehicle (flip through the manual and make sure you like it before you buy it), remove the battery and have it tested, check all the engine compartment fuses. If you find blown fuses, do not replace them right away as you may just blow the new fuse. Instead check the wires or devices connected to a blown fuse for a shorted or grounded wire. Also make sure all charging system connections are clean (shiney metal) and tight. Having had an alarm system that was removed, you may find there are O.E.M. wires that were spliced into and not properly repaired that are causing some problems. This is where a wiring diagram of this cars ignition system would come in handy. Good Luck!
Nov 29, 2008 at 1:08 PM
