2005 Dodge Magnum
2005 DODGE MAGNUM
NYEREPAIR
I have an '05 Magnum. V6, auto, 2wd.
Recently, the speedometer stopped working.
I can find no info around as to whether it is cable operated as with cars in the past, and if so, is that attached to the tranny. It is still under warranty, but getting it to the shop and waiting around is less appealing than just fixing it myself, if it can be done.
Thanks Guys !!
May 26, 2007 at 11:44 AM
E40WATER12
  • 522 POSTS
If the trucks under warranty I would have it take in right away, Are you getting check engine light on?.
Could have a burnt out speedo cluster.
May 27, 2007 at 1:27 PM
NYEREPAIR
The entire dash works fine except the speedometer.
May 27, 2007 at 6:05 PM
