1998 Dodge Intrepid Underfloor Noise
ALJENKATH
1998 Dodge Intrepid ES, 3.2 L V6, 101610 miles. I brought the car in for a problem with the steering and it was corrected by replacing the front tie rod ends. But now I get a loud noise from underneath the car. The dealer has looked at the car for a week and can find nothing but a clamp missing on an exhaust pipe near the catalytic converter. He dos not think this is causing the problem but cannot find any other cause. The pipe he mentions has a welded clamp on it and he says it is attached to the converter. Do you think this could be the problem? When the noise is bad, I can feel a thumbing on the floor of the car by the gas pedal.
Greg
Jul 5, 2007 at 1:06 PM
SERVICE WRITER
  • 9,123 POSTS
If the noise wasn't there previously, I would wonder about the tie rods. My guess is they are the inner, where a bushing kit is used to repair them. We have had them loosen up from technician error, but don't know if that's your case.
Jul 5, 2007 at 2:08 PM
ALJENKATH
I brought the car back and the dealer had it for a week and no luck. They even undid the repair and put it back together. They are at a loss for the noise. It appears to come from the bottom of the car and only starts after the car has been driven several miles. Even if parked and then driven it is there.
Jul 6, 2007 at 8:37 AM
SERVICE WRITER
  • 9,123 POSTS
My advice would be to take it to an independent shop. Talk to the owner if possible and ask if he were to use it as his personal car since the nosie didn't show up. However first ask him to diagnose the noise of the thumping. At the end of the day, if they can't re-create the problem then suggest the above scenario. Sometimes telling the "tie rods" or whatever was replaced can help to zero in on a problem, or also just throw smoke and mis-direct a tech.
Jul 6, 2007 at 11:37 AM
Suggested Repair
Have an independent shop diagnose the heat-related thump, focusing on inner tie-rod bushings that may have loosened after the recent repair, and inspect the exhaust clamp near the catalytic converter.
Conversation Summary
A 1998 Dodge Intrepid developed a loud underfloor thump, felt near the gas pedal, after front tie-rod ends were replaced. The noise appears only after several miles of driving. The dealer found a missing exhaust clamp near the catalytic converter but could not confirm a cause. The expert suspects loosened inner tie-rod bushings from the repair and recommends an independent shop diagnose the thump, noting the recent tie-rod work.
