Squeak Coming From Front end
TPEARS01
2001 Dodge Intrepid ES 3.2L. Hello! I'm not sure what category this would be under, but I am having a problem with something in my front end. There is a squeak/squeal coming from my front right tire on my Intrepid. It only makes the noise when making a left turn and stops when applying the brakes. I just replaced both front rotors and pads, but the noise is still there. The car has never given me a problem before, so I'm hoping that it is nothing serious! Any informaion would be greatly appreciated! THANKS!
Jun 19, 2007 at 3:36 AM
STACILS
Did you ever find out what the problem was? I am experiencing the same problem right now???
Jul 20, 2009 at 6:01 AM
DOCONEMUG
The problem is an easy fix. On the front right brake rotor on the inside is a small metal panel that is supposed to keep crud off the rotor. It is too close and rubs the rotor. Get under there and pry it away from the rotor to about 3/16 inch clearance, your problem will be gone. Just did mine actually
Feb 16, 2016 at 4:12 AM
