rough idling
DODGE INTREPID
KEVBOB
Car seems to be idling rough, when in park car RPM needle goes past 2 and then stays there, when car is put into drive RPM needle comes back down. Car accelerates without pushing gas petal, it has done that two times. When it first starts up in the morning it does do it, but as car warms up it starts acting up. Could this possible have something to do with the cruise control? I have not used the cruise control but is it possible that is froze up.
1996 Dodge Intrepid
3.3 liter 120,000
Feb 11, 2007 at 6:55 PM
MIKE H R
  • CERTIFIED EXPERT
  • 3,094 POSTS
check the throttle cable on the engine. make sure everything is loose and lube the cables. could be one is sticking. spray with wd 40
Mar 6, 2007 at 3:24 PM
