2004 Dodge Intrepid Phantom battery drain?
52,000 MILES • 6 CYL • FWD • AUTOMATIC
WHITEDB
Several months ago I had a license plate light wire repaired. 4 days later the battery drain started. It has happened 3 times since the garage repaired the wire. The car will run fine and upon sitting 4 hours, or a week, the battery is completely dead. The garage that is working on it now states that it can't be draining the battery because of that light repair?? What do you thinik? I am a lady driver and need some advice. This complete drain is random.
Jan 21, 2008 at 7:48 AM
  • 75,988 POSTS
If its not the repair of the license plate lights then there's a short in the electrical system get them to check it out
Jan 22, 2008 at 10:28 AM
