2003 Dodge Intrepid timing chain
2003 DODGE INTREPID
DANNYNICOLS
Engine Mechanical problem
2003 Dodge Intrepid 6 cyl Front Wheel Drive Automatic
iif the cam gears move a little when you remove the chain is that ok
Jan 14, 2009 at 3:22 PM
  • 110,241 POSTS
Hi:
Most likely is isn't ok. when you put the new belt back on, make sure the timing marks are where they belong or you will be taking it apart again. Refer to the Timing Belt Marks site on this page as a referance.
Jan 20, 2009 at 11:57 AM
