2002 Dodge Intrepid Instrument Cluster
102,999 MILES • 6 CYL • FWD • AUTOMATIC
BLACK1999
Where to find the fuse for an instrument cluster!
Mar 24, 2009 at 7:58 AM
CARADIODOC
  • 34,414 POSTS
The instrument cluster talks to the body computer which talks to the engine computer. You didn't say what's wrong so I'm assuming it's totally dead. The most likely culprit is a defective ignition switch. The second most likely suspect is the cluster itself, but I don't remember ever running into a dead one on an Intrepid. It used to be REAL common on older Neons.
You might find a fuse under the cover on the left side of the dash board, (gotta open the door to see it), labeled "Gauges".
If you don't find a blown fuse, please be more specific of what's wrong; otherwise we're just guessing without knowing all the details.
caradiodoc
Mar 24, 2009 at 10:01 PM
