2002 Dodge Intrepid Blinking Check engine light
120,000 MILES • 6 CYL • FWD • AUTOMATIC
SCOTT RICHEY
While replacing timing belt, the starter burned out.
Not getting 12 volts to Coils.
ASD is new
Oct 26, 2009 at 12:51 AM
CH112063
  • 1,320 POSTS
Is this a 3.0L. Is it a Mitsu engine?
And when you turn the key what do you hear.
Does the check engine lamp work ok?
Was the battery disconnected and is the cam sensor plugged in? Does it crank over?
I hate when that happens. And it does happen. Joe
Oct 30, 2009 at 4:18 PM
