I have a 2001 dodge intrepid with a 2.7l ,and I just had the water pump replaced.Prior to that it would run rough very little and the engine light would flash on.Now it will start and the idle will come up as usual but when it comes down it idles real rough and it will not go over 3000 rpm, you can't drive the car at all because it will stall.I have replaced all the coil packs,the spark plugs,air idle control motor,throttle position sensor,and ignition switch. Is it possible that it could be the fuel pump or something like a sensor or relay.Any help would be great
thanks
Frank
thanks
Frank
Apr 13, 2010 at 2:28 PM
