Electrical problem
2000 Dodge Intrepid 6 cyl Front Wheel Drive 83,000 miles
I have a 2000 Intrepid with 83,000 miles. Over the past couple of months, this car has started to develop a problem with starting. Frequently, I turn the key and nothing happens, sometimes the engine will turn over a little bit. Move the steering wheel and it cranks right over. I have checked the battery and charging system, all check out OK. This morning, with an outside air temp of 35 degrees, I couldn't get this thing to turn over at all. It took about 5 minutes of moving the steering wheel a back and forth before it finally cranked over enough to start. Car runs perfectly fine once started, no stalling or hesitating at all. Any ideas??
Thanks in advance!
Thanks in advance!
Oct 27, 2008 at 2:35 AM
