2000 Dodge Intrepid trunk button
2000 DODGE INTREPID
127,671 MILES • 6 CYL • FWD • AUTOMATIC
SUPERCHICKEN1961
When I press my trunk button on the dash, the trunk does not unlock.
Sep 8, 2009 at 2:38 PM
CH112063
  • 1,320 POSTS
Usually the electric latch connector or the latch switch goes bad. You can use a 12 volt test lamp to check that there is input to the switch and a change when the button is pressed. If that checks ok, go get a replacement switch or latch. If the button doesn't change the latch's inputs at all first check the fuses then bring it to a shop for service.
Sep 11, 2009 at 8:55 AM
