2000 Dodge Intrepid ECM/PCM
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
SASHARMAND
First of all, are these two terms different or are they the same when talking about replacing it/them. I am asking this question because in my repair manual I do not see anything that says ECM -- but, refers to only the PCM. At the auto store they refer to it as the PCM...
Secondly, my engine light is on due to the following OEM number (P0601) and the following is a list of probable causes...according to a printout given to me by auto store.
1. - Shorted input sensor
2. - Shorted electrical circuit
3. - Failed ECM
On that note, I want to go in order when troubleshooting and hopefully not have to get the $450.00 ECM replaced...where is the input sensor and how do I check to see if it is shorted/electrical circuit?
Mar 5, 2008 at 9:27 AM
BMRFIXIT
  • 19,053 POSTS
GM and some other manufactures call it electronic control module ECM
dodge call s it powertrain control module PCM
same …..same.
P0601 is an internal controller failure
most likely you need to have the PCM replaced
(defective PCM)
Mar 5, 2008 at 11:07 AM
