1999 Intrepid stalling-This is stumping the dealer
DVINTI
  • 1999 DODGE INTREPID
I have a 1999 Intrepid 2.7 liter 6 cyl with 139,000 miles.
The car will sputter as I'm driving and stall. I try to restart it and when it does, it runs real ruff(rpm's at 500) and when I mash the gas it stalls. After about 30-60 minutes I try to restart it and it runs fine for a few days and we start the process all over. First time at the dealers, they chaged the plugs and MAP sensor. Second time at dealer they unpluged the AC Pressure Transducer-next day same thing. It is again at the dealers and the scanner states- MAP Voltage High(P0113), Intake air Temp sensor volts High(P0300), Multiple Cylinder misfires. They say that all these senor code share the same ground on the computer. The mechanic today(5/30) drove it for 60 miles and could not reproduce the problem. They said they were going to test the pressure of the fuel pump. I don't know the outcome of the pressure test for the fuel pump. The check engine light does blink then stays steady. Sometimes when I sucessfully restart it the check engin light is off. HELP!
Wednesday, May 30th, 2007 AT 6:46 PM
E40WATER12
  • 522 POSTS
Sounds to me either their is a problem with the injectors aren getting fuel, Or pressure regulator is wornout, Could have a vacuum leak in a hose or in the intake system. Also states- MAP Voltage High(P0113), Intake air Temp sensor volts High(P0300), Multiple Cylinder misfires, Has the wiring been checked for shorted wires, or corrioded. Could have a problem with th e coil packs.
Thursday, May 31st, 2007 AT 4:42 AM
DKSHAVCE
  • 14 POSTS
Hey dont know if u had that checked yet but
on my 94 int 3.3l I had stalling problems and had traced it back to an open EGR valve
Wednesday, June 6th, 2007 AT 7:19 PM
OLDTECH2
  • 64 POSTS
Get the dlr to check the capacitor in the green/red wire to the coil packs. My '96 had a similar problem with the shutting down. I wound up replacing the capacitor and it's runs fine since. The capacitor was in the engine wire harness about 6" up from the coil plug.
Good check is to heat the capacitor up with a hair drier. The engine will die. Then cool it down, and the engine will restart.
Saturday, July 14th, 2007 AT 8:47 PM
THESHADOWKNOWS
Replace the Crank Position Sensor and the problem should go away!
Tuesday, September 18th, 2007 AT 4:53 PM
