1999 Dodge Intrepid The key turns but wont crank
CWILLY
  • 1999 DODGE INTREPID
  • 6 CYL
  • FWD
  • 142,500 MILES
About 3 months ago I was driving and the motor shut off going down the highway. The car restarted after a few min. It started doing this 2-3 time a week to 2-3 times a day. Also sometimes I would turn the key and nothing try it several times and then it would work. I have noticed while driving it wont shut off but all the gauges go to zero including the speedometer, Its like I shut off the key. Now it wont start at all. I have replaced the battery, ignition switch and have moved some off the relays around under the hood. It has a sentry alarm thing so it takes a special key which I have not changed. Any suggestions would be great. I would also like to know how to bypass/ test the sentry system.
Tuesday, July 20th, 2010 AT 2:32 PM
  • 109,959 POSTS
Honestly, I feel the problem lies in the aftermarket alarm. It can shut the vehicle down. As far as the sentury system, you need to contact someone that sells that system.
Wednesday, July 21st, 2010 AT 12:36 AM
  • 109,959 POSTS
Hi:
First, thanks for the positive feedback. It is appreciated. Second, I wish I could have been more help. If you have questions or other problems, please let me know and I'll do my best to help you.
Saturday, July 24th, 2010 AT 10:17 PM
