1999 Dodge Intrepid oil pressure switch
HERBERT1626
Electrical problem
1999 Dodge Intrepid 6 cyl Automatic
I want to know how to change a oil pressure switch for a dodge 1999 2.7 also i want to know where it is located at in the motor
Oct 18, 2008 at 8:11 AM
JNOVACK
  • 723 POSTS
Raise vehicle on hoist.
Position an oil collecting container under switch location.
Disconnect electrical connector.
Unscrew oil pressure switch
then your ready to reinstall
Apply Sealant to the switch threads.
Install oil pressure switch to fitting.
Connect electrical connector.
Lower vehicle.
Start engine and check for leaks.
Check engine oil level and adjust as necessary.
Oct 18, 2008 at 9:08 AM
RFB91
The oil pressure sender is located on the passenger side of the 2.7 engine just above the motor mount. Get to it from below.It has a single wire connector going to it.
The spec for the light to turn on is is 4 psi, idle oil pressure spec is >5 psi. Not much difference. After your done, search Google for all the horror stories about oil pressure problems with the 2.7 liter Chrysler engine.. !!!
Nov 8, 2008 at 1:04 PM
