1999 Dodge Intrepid es
RATORREY
We just purchased this car with 60000 mile on it. 3.2 liter 4speed autostick transmission. My wife drove it through the car wash (had under carriage washed) and apon exiting the car wash and putting the vehicle in drive it would not move. She shifted between park and drive a couple times, is sure it was in a drive gear (no luck). Checked Ebrake (no luck) put the car in Reverse fealt what seemed like something engage or disengage and the car moved and appears fine. Her explanation to me was that it fealt like the right rear wheel was locked up. She stated she noticed what appeard to be a grease/oil smell coming from that wheel. I was not there and do not have any first had knowledge. Anyone have any thoughts? ABS locke up? Transmission glitch?? or general quirk?
Richard
Jan 4, 2006 at 4:54 AM
What to check next
Diagnostic guidance. Suggested checks and possible repairs are separate from the owner's reported results.
Have the reported wheel binding and smell inspected, and retrieve relevant diagnostic codes. Give the shop the exact sequence rather than assuming a transmission fault.
Guidance references and applicability
Source: This question and its visible discussion. The roadmap distinguishes the original owner's reports from other participants' experiences; proposed follow-up is editorial guidance, not a confirmed diagnosis.
Read the replies · Discussion summary and reported outcome
  • 55,560 POSTS
Sounds like you may have transmission or a transmission controller problem. :cry:
Jan 4, 2006 at 7:06 AM
RATORREY
Can you help me out here a little more? Before the undercarriage wash and even now after that one incident the transmission goes into gear properly and shifts smoothly no niticeable issues. What do you think happend with the under carriage wash? Something get wet? Something stick? Are you saying that it appears the transmission did not know it was being shifted into a gear?
Jan 4, 2006 at 7:13 AM
  • 55,560 POSTS
I dont think the under car wash would hurt it. It is almost water proof. Scan the PCM to check for trouble codes.
Jan 4, 2006 at 9:22 AM
Discussion summary
A 1999 Intrepid briefly would not move forward after a car wash. The driver felt a possible right-rear-wheel bind and noticed an oily smell; selecting reverse released or engaged something, after which driving appeared normal.
Reported outcome: The owner reported normal shifting after the incident, with no confirmed cause or repair.
The account was relayed by the driver's spouse. The car wash preceding the event does not establish water intrusion, ABS failure or transmission failure.
Read the original discussion
