1999 Dodge Intrepid
COBBWJ
  • 1999 DODGE INTREPID
1999 Dodge Intrepid Automatic 148000 miles
I started my car and it would not move forward or reverse. The tires would not even spin. I don't know if its because of the cold or what is wrong, what could be the problem?
Monday, December 15th, 2008 AT 12:09 AM
BLUELIGHTNIN6
  • 16,542 POSTS
When you pressed the accelerator while in gear does the engine rev up? If so, it sounds like you may have a serious internal problem with your transmission. While the vehicle is running, is there an overdrive (OD) light that is flashing?
Monday, December 15th, 2008 AT 12:55 AM
