1999 Dodge Intrepid
TERRY LUFT
  • 1999 DODGE INTREPID
Electrical problem
1999 Dodge Intrepid 6 cyl Front Wheel Drive 150000 miles
Engine wont shut off when key is turned off or taken out, (not dieseling) runs fine, also several of the little dash warning symbol lights stay on, ignition switch seems to work fine
Sunday, February 10th, 2008 AT 1:59 PM
BMRFIXIT
  • 19,053 POSTS
And how do you shut it off
do u have aremote starter
you have a feed back to ignition check that
Tuesday, February 12th, 2008 AT 7:39 PM
TERRY LUFT
Have replaced the ignition switch. No remote starter.
I have to remove cluster fuse on drivers side panel or asd relay under hood to kill engine. But with the cluster fuse removed the engine starts and stops normally, but all of the small warning lights remain on after you shut it off and remove key.
Tuesday, February 12th, 2008 AT 8:39 PM
BMRFIXIT
  • 19,053 POSTS
If no wiring done on it
may next step is to remove and unplug the cluster and try
let me know
Tuesday, February 12th, 2008 AT 8:48 PM
TERRY LUFT
I removed the cluster and the engine still wont shut off. I have to remove the cluster fuse #14 for the switch to turn engine off/on normally. Now after reinstalling the cluster and all parts the head lights and tail lights wont shut off either along with all the small warning lights that never go out. Must be a short somewhere? Do you think its in the fuse panel itself?
Monday, February 18th, 2008 AT 9:54 AM
