1997 Dodge Intrepid turns over but won't start
1997 DODGE INTREPID
20,000 MILES • 6 CYL • FWD • AUTOMATIC
DALLANN
I have had the car for about one year with no problems. tune up-belts-hoses-spark plugs and wires all replaced. my notmal gas 24mpg. on saturday i drove the car with no problems. on sunday when i went to start it - it turns over fine but won't start. in the past the check engine light flashed for a second about 3 times over four months but they were unable to diagnose it. the only thing new is that when i try to start it the oil light never comes on. i had it changed about 400 miles ago and it still shows fine on the stick. please give some advice if you can.
thanks i am broke and stuck at a hotel and have no money for a donation. someone else is paying for my costs now.
May 20, 2010 at 12:57 PM
  • CERTIFIED EXPERT
Do below to get a basic idea what's with the fuel and spark
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine atleast 3/16 away from ground-have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
May 20, 2010 at 3:25 PM
