1996 Dodge Intrepid car sitting for a year
112,000 MILES • 6 CYL • FWD • AUTOMATIC
KIMYSIOUX
my question is my intrepid has been sitting for a year, now ready to get it back on the road for my son. My question what kind of work should i do after sitting for so long? I know i should rotate tires and check all fluids, but would it need a tune up? Its also pretty dirty under the hood and ive heard you can take it to a car wash and hose it down but are there parts i should try to avoid before hosing off? thank you in advance
May 5, 2008 at 3:55 PM
RAHMEL23
  • 6 POSTS
[quote:15eb57583f="kimysioux"]Engine Performance problem
1996 Dodge Intrepid 6 cyl Front Wheel Drive Automatic 112000 miles
my question is my intrepid has been sitting for a year, now ready to get it back on the road for my son. My question what kind of work should i do after sitting for so long? I know i should rotate tires and check all fluids, but would it need a tune up? Its also pretty dirty under the hood and ive heard you can take it to a car wash and hose it down but are there parts i should try to avoid before hosing off? thank you in advance[/quote:15eb57583f]
ok i would do a fill tune up plug wires gas and air filter pcv valve change that anitfreez and have a shop look under the car cuz if the car was setting on the grass for and year most likely it rotted under and have them check all of your brakes and rotors cuz i know that thay r rotted out too,and i would fill the tank up and put same fuel injecter cleaner i love too use techron its good stuff
May 5, 2008 at 4:21 PM
