1995 Dodge Intrepid Over Heating
DJUDY
  • 1995 DODGE INTREPID
  • 6 CYL
  • MANUAL
  • 98,250 MILES
The engine over heats. Fans come on after several minutes during warm up. I have been told that it maybe a head gasket issue. If that is true would I not have oil in the water or water in the oil? I do not have either. Any suggestions
Sunday, May 17th, 2009 AT 9:01 AM
CRUISE816
  • 7 POSTS
It depends. I had the same problem with my 94. The problem with mine was the gasket between the inner and outter intake manifolds was leaking. I know it sound dumb but there is coolant running between thats where the thermostat is located. I have the 3.5 if you have the same motor I would start with the therm and then check the intake gasket. Let me know what you find out
Monday, June 1st, 2009 AT 10:05 PM
