1995 Dodge Intrepid 1995 Dodge Intrpid Gear
1995 DODGE INTREPID
13,600 MILES • 6 CYL • 2WD • AUTOMATIC
CPD024
I just got my car fixed because it turned off on me while i was driveing and it was timeing issue and they went about run computer test on it and siad one my fusses was blowen and it wasnt causeing it to shift wrong and they told me it was the cigrate lighter and horn fuse.Well it worked fine for a few days and then it start shifting wrong again and a problem i had before also of where i could start car and put it in drive and couldnt tell me what gear i was in just all lights would be lit up on dash area that tell you what gear youre in and it dosnt tell me how fast it going.So thicking it was fuse i went got a new one and it wasnt blew fuse wasnt but i changed it and does it off and on.What coudl eb causeing this.
Apr 4, 2010 at 12:42 PM
CH112063
  • 1,320 POSTS
If you have a wire touching metal somewhere the fuse will blow at weird times when you make a turn or use something. Did you happen to ask them what the fault codes the computer was telling them? The transmission's computer stores a code to tell you what wiring is not right. Call and ask them what code they got, get back to me, ok?
Apr 6, 2010 at 3:27 PM
CPD024
i called them and the guy who worked on it is out of town and also not want to shift right when the car does not show if i am in park,netural,drive and so on.i keep checking all fueses in car when it seem to do this but none of them are blew.It seems to work sometimes and then sometimes it dosnt want to work at all.
Apr 8, 2010 at 3:09 PM
CH112063
  • 1,320 POSTS
If your still having problems it should be coming up with fault codes that the TCM or PCM are storing, this is the way we locate problems that cause sudden downshifts or no upshifts, the transmission control module itself may even have an internal fault requiring replacement. It's best to see what codes he had. I'm here all the time, let me know if I can advise you or give you code interpretations. ok
Apr 8, 2010 at 4:32 PM
