I lost my belts last night on the highway. i found the main drive belt wrapped around the crankshaft pulley shaft. I cut it off prior to installing the new belts and once the belts were replaced, it runs great. When I reached the house, I popped the hood and oil was all over the place. I believe there is a seal behind the crank pulley that I may have damaged with all the serpentine belt wrapped so tightly on the shaft. My question is can I just change that seal by removing the core support, radiator and pulley or do I need to go through the oil pan to replace the seal. Is it more than a seal? Is it bearings too?
Help. 1994 Intrepid, A/C, PWR Steering, 3.3 L and I have 142,000 miles on it. Great car just a misfortune with blowing the belts at 70MPH.
Zach
Zach
Jul 6, 2007 at 2:19 PM
