1991 Dodge Dynasty intermidiate vehicle running
1991 DODGE DYNASTY
166,000 MILES • 6 CYL • FWD • AUTOMATIC
PETER123
car will apparently run till it gets warm,then die--wait 5 minutes and you can start up and drive a mile or 2 ,then it dies again---repeatedly. this happened with no early warning signs. I had someone check it out,but he can't find the source of the cause.if you leave the hood open,it seems to be -OK--some heat problem?other than that ,the car is extremely reliable--can you HELP? Sincerely,Peter
Jul 27, 2010 at 11:59 AM
CARADIODOC
  • 34,367 POSTS
Hi peter123. Welcome to the forum. Have you checked for diagnostic fault codes? Do you know how to do that with the ignition switch? Which engine do you have? Crankshaft position sensors often fail from heat.
caradiodoc
Jul 27, 2010 at 12:32 PM
PETER123
Thank You for your suggestion-I will pass this on to the mechanic here. i'm praying!
Jul 27, 2010 at 12:51 PM
