1990 Dodge Dynasty
1990 DODGE DYNASTY
SAMUEL713
Engine Performance problem
1990 Dodge Dynasty 6 cyl Four Wheel Drive Automatic
my car starts up but want stay on i think it may be my oil pressure line
Feb 24, 2010 at 11:15 AM
CARADIODOC
  • 34,381 POSTS
How long will it stay running? Will it run if you hold the gas pedal down?
If it only runs for two seconds, then shuts off, it's in anti-theft mode. Unlock either of the front doors with the key to disarm the system.
If it will run if you hold the gas pedal down, the battery was likely disconnected or run dead. "Minimum throttle" must be relearned by the engine computer before it will know when it must be in charge of idle speed. To meet the conditions necessary for the relearn procedure to occur, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the brake or gas pedals.
caradiodoc
Feb 25, 2010 at 11:49 PM
