I have a 2001 Dodge Durango with the 4.7L. It has 156000 miles on it. It is four wheel drive. When I had tires put on it recently, the tire tech told me that I had a wheel bearing starting to run dry and fail. How do I determine which side of the vehicle has a failing bearing? While driving, when I turn the vehicle left, I hear sort of a howling noise. I thought it was due to my tires, I run BFG All Terrains, but it doesn't make noise when I turn right. I have jacked up each side of the vehicle, and by grabbing the top and the bottom of the tire, checked for movement. I didn't feel any. Also, when I spun each wheel, the only drag/noise I heard was the brake pads against the rotors. I'm stumped, any help will be greatly appreciated.
Nov 26, 2007 at 6:21 PM
