Okay, well I believe once we solve the first issue that every thing else will be solved as well. I still believe the door ajar switch is the issue. Your model vehicle is equipped with the inner door switch. This is why the WD40 in the door jambs had no effect, because it didn't reach the switch. They are attached to the locking mechanism inside of the door panel. Your power locks and the memory accessories you speak of will not work correctly because the computer thinks one of the doors is open (test one that is used most first).
Let me know what happens with oil on the switches, I will follow up.
Thanks for using 2CarPros.com!
Feb 3, 2009 at 11:38 AM
