2004 Dodge Durango Dodge does not move
2004 DODGE DURANGO
75,000 MILES • 6 CYL • 2WD • AUTOMATIC
COTTONCANDY29
how do you change an oil pump?where exactly is it located?how much does this cost?
May 18, 2010 at 9:38 AM
  • 110,194 POSTS
The engine oil pump is located inside the oil pan. In your case, you will need to lift the engine to remove the pan and then unbolt the pump. The pump will most likely be around 75.00 based on where you live.
Jun 7, 2010 at 1:48 PM
