2003 Dodge Durango everything
2003 DODGE DURANGO
70,000 MILES • V8 • 2WD • AUTOMATIC
BIGLUTE
it wont pass inspection, says its the map or maf sensor. ac only blows out at feet or windshield. leaking something that smells really bad in the front passenger by the feet. I wanna get it all fixed with income tax. Should I go ahead and throw in a complete tune up? If so, what comes with it? Should I go ahead and flush out the radiator, engine, and transmission. Should I also change out the oil and fuel pumps? Can you tell me in detail please all parts and labor so I know what to expect, thank you.
Jan 15, 2009 at 10:02 PM
  • 110,194 POSTS
Hi:
If it won't pass emissions, only replace the part that is bad. As far as a tune up... in general they include spark plugs, ignition wires, distributor car and rotor, fuel filter, and an air filter if needed. An oil and filter change should be done every 3000 miles, but the oil pump should be fine unless you lost oil pressure. They rarely go bad. The same with the fuel pump. If it still works, let it alone. A fuel filter is good preventative maintenance, as is transmission service every 30K miles, and the radiator flush should be done too if it's over 3 years old.
Finally, the leak on the passanger side that smells sounds like the heater core is leaking. Yes, it needs fixed. As far as the a/c if it only blows on the windshield and the floor, there either is a vacuum leak (which directs the air flow) or a vent door is damaged.
Listen, you have a lot of questions. I tried my best, but if you have something specific, let me know. Also, follow the owner's manual maintenance schedule. It will provide what the manufacturer recommends.
Jan 31, 2009 at 3:20 PM
