2000 Dodge Durango Smoke
DANHOP
  • 2000 DODGE DURANGO
Engine Mechanical problem
2000 Dodge Durango V8 All Wheel Drive Automatic 249k miles
My son was driving, said the engine made a noise and then smoke from the engine. Oil on the road.
Is the engine blown? Other possibilities?
Monday, July 5th, 2010 AT 9:03 AM
  • 109,936 POSTS
Can you tell where the oil came from? It could be a bad oil filter, oil plug, or wort case, a rod may have cracked through the engine block. Do you see any indication of that? Also, let me know what kind of noise he heard before this happened.
Monday, July 5th, 2010 AT 10:34 PM
DANHOP
Oil was from underneath, passenger side. It was a low humming noise then a sound of a crack then the smoke.
All appeared normal from above and did not appear that any crack took place
Tuesday, July 6th, 2010 AT 6:19 AM
  • 109,936 POSTS
That is the side the oil filter is on. Check to see if it came from there or the oil sending unit. Also, check the engine block to make sure nothing has damaged it from the inside.
Tuesday, July 6th, 2010 AT 4:16 PM
