So my vehicle struggles to shift out of first gear when you give it too much gas. It will basically red-line if you press to much on the gas, but at lower RPM's, it shifts fine.
What could the problem be?
Monday, February 9th, 2009 AT 11:52 AM
JCORZINE
MEMBER
This happens when the catalytic converter starts to plug up because it changed the vacuum the computer sees. We can confirm the issue by following this guide.
