1973 Dodge Dart stalling engine
23,000 MILES • V8 • 2WD • AUTOMATIC
LUGERRORY
when i start my car in cranking position it starts with the starter in cranking positon.when i have it the regular on postion it stalls .lateley the car seems to stall when i get low on fuel.but i was able to keep it running now it will only run if i keep the starter in cranking position
Oct 16, 2009 at 4:33 AM
HMAC300
  • 48,601 POSTS
i think what you are saying when you put itin the starting postion it starts then quits when it goes to the on position. If this is the case you ballast resistor is probaly shot. it's the white block on your firewall. They are cheap and easy to replace....
Nov 15, 2009 at 6:56 AM
