fuel pump
DODGE DAKOTA
BJAJGRIFFIN
This has happened to me twice in the last two weeks.After driving about thirty min. when it is hot and running the air. The fuel pump appears to stop working.I turn the key on but cannot hear the pump for the 15 sec. it says you should be able to hear it at gas tank.After the truck cool for about an hour it will crank and run good.Both times this has happened I was in traffic and idling and it just quit. Joe
May 11, 2007 at 7:56 AM
  • CERTIFIED EXPERT
[quote:8195f14af2="bjajgriffin"]I have a 1999 dodge dakota v6 with 85000 miles.
This has happened to me twice in the last two weeks.After driving about thirty min. when it is hot and running the air. The fuel pump appers to stop working.I turn the key on but cannot hear the pump for the 15 sec. it says you should be able to hear it at gas tank.After the truck cool for about an hour it will crank and run good.Both times this has happened I was in trafic and idling and it just quit. Joe[/quote:8195f14af2]
Check the fuel pressure, also test the ASD relay this one powers the pump
May 11, 2007 at 8:08 AM
POOPYRYA
  • 17 POSTS
I recently replaced the fuel pump assembly and things were fine until horrible road conditions. Truck refused to start, no fuel pressure.
Anyway, the spout on the rollover valve had broken off in the pressure tube, too close to the valve to rig it. I'm trying to find a compatible substitute because nobody makes it and the local car cannibal lot has nothing.
Aug 18, 2019 at 1:08 PM (Merged)
DANNY L
  • CERTIFIED EXPERT
  • 5,648 POSTS
Hello, I'm Danny.
Yes, you're in a tough spot.Dodge can't provide a part number due to being discontinued. Dorman doesn't make one either. Junk yards are you best bet be it looks like you didn't have luck.You might want to try some type of heavy duty epoxy or PCV type glue. You might want to use skinny needle nose pliers to remove the broken piece gently out of the hose and glue it back together until you find a replacement. Hope this helps and thanks for using 2CarPros.
Danny-
POOPYRYA
  • 17 POSTS
Got the piece out but the stump on the valve housing is so short i've been defeated.
I don't know how long ago was posted, but my brother found a forum stating that part number 911-001 is all I needed. Of course the parts site says it won't fit. But that's why I thought JCD should have at least a few shared parts, but I can't find a definitive answer yet.
Any more advice would be appreciated beyond my vocabulary to express.
DANNY L
  • CERTIFIED EXPERT
  • 5,648 POSTS
Hello again.
Do you have any LKQ wrecking yards in your state? So far that's all I can find. Or look for someone in your area on Craigslist who is parting out a similar Dakota.
Danny-
POOPYRYA
  • 17 POSTS
I've never heard of it but I'll see what I can do. I appreciate the help, thanks!
DANNY L
  • CERTIFIED EXPERT
  • 5,648 POSTS
Hello again.
What state/city do you live? I can send you a link..
Danny-
POOPYRYA
  • 17 POSTS
I'm in Corpus Christi Texas.
  • CERTIFIED EXPERT
  • 53,872 POSTS
I have seen people drill out the plastic and install a small pipe thread fitting to attach the rubber hose to. Does that part come with a new fuel pump module? Check out the diagrams (below). Please let us know what happens.
POOPYRYA
  • 17 POSTS
I'm not sure which part is the module. I ended up reaming the plastic and inserting a 1/8" roll pin, fiber glassed the top together and put the hose back on. I was lucky to save the nipple part that broke off in the first place. It is not pretty but it worked.
DANNY L
  • CERTIFIED EXPERT
  • 5,648 POSTS
Here's the local Texas LKQ's.
Hope this helps and thanks again for using 2CarPros.
Danny_
  • CERTIFIED EXPERT
  • 53,872 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
JIM COFFMAN
I replaced the heads and when I tried to start the engine. No fire and no fuel pressure. Took to a repair place. No luck. Replaced the computer. No relief. The alternator was drawing the battery down. Disconnected the alternator and the fuel pressure came on. There appears to be feedback throught the relays in the engine compartment. Have checked and double checked the connections, but have not checked the alternator. It appears that this is above my talent level and my mechanics. There must be a short or hot to ground problem but have been unable to trace the correct locationl. Help Thanks JIM
Aug 18, 2019 at 1:09 PM (Merged)
2CARPRO JACK
  • CERTIFIED EXPERT
  • 11,533 POSTS
Jim, you may want to try going here
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
Full wiring diagram for your truck. The computer controls th ealt in your truck, have the alt bench tested to see if it is throwing ac current, this will mess with the comp
  • CERTIFIED EXPERT
Find the automatic shutdown relay ASD relay and test it -if this relay is shorting out it will affect the coil/injectors and fuel pump circuits.
JOHNSTONB60
Please Help This past January my dakota stalled after just pulling out of the driveway. After doing all the normal inspections found that it wasnt getting fuel pressure. So i had the fuel pump changed out, and it ran again yay yeah for 1 month. So after inspecting again figured the fuel pump went bad again since there was no fuel pressure. It was under warranty so I went and got another one the same one and brand which probably wasnt smart. It wont start now but it does turnover and will run momentarally if i prime the throtlle. Is there maybe an electrical problem. I cant get fuel to the throttle PLEASE HELP Fuel to the throttle=me at the lake
  • CERTIFIED EXPERT
Verify that you're getting the correct fuel pressure if so check for injection pulses
JOHNSTONB60
Thank you very much for replying. I am not getting any fuel or pressure to the throttle body also am not hearing the fuel pump come on. After reading through the forum seen this problem answered by checking the ASD relay which I will do today. My marking lights in the rear also do not come on when i turn the headlights on i dont think this is related but thought id throw it out there. Any other sugestions thanks again.
  • CERTIFIED EXPERT
Check fuse C 40amp and fuse D 30 amp in the power distribution center-if okay test the fuel pump relay its relay no.5 in the PDC. and also relay no.3 for the ASD relay.
JOHNSTONB60
Thanks alot for all your help. I changed out the fuel pump relay and the ASD relay and it started. First I switched just the fuel pump relay but it didnt start. But then switching the ASD relay did the trick. You are the man. The walleye wont know what hit em.
DIGGER1971
Ran when I parked it. Then it sat for two months now the thing will not start its got good spark but fuel pump and injectors not working. Fuel pump does not sound off when I turn it over. I did hot wire the fuel pump just to make sure it worked and it did but after cranking the engine over and over my spark plugs still bone dry any suggestions would be greatly appreciated.
CJ MEDEVAC
  • CERTIFIED EXPERT
  • 11,004 POSTS
Here's what I came up with:
Check Fuse D (30A) and Fuse C (40 A) in the power distribution center (PDC)
Also check these two relays in the "Prodemand" diagram I'm posting below.
Return with a grin!
The Medic
POOPYRYA
  • 17 POSTS
I had very similar issues; changed the crankshaft sensor and was good to go! Best luck to you
Aug 22, 2019 at 2:23 AM
  • CERTIFIED EXPERT
  • 53,872 POSTS
Excellent addition to this thread! Please feel free to help out whenever you are on the site :)
Aug 22, 2019 at 11:50 AM
