2007 Dodge Dakota Hesitation
71,000 MILES • 6 CYL • 2WD • AUTOMATIC
CHARITYH24
I sometimes when I am driving down the highway the truck starts to sputter, and it slows down, sometimes this continues for 5 minutes and stops and others it happens for a while.
I have cleaned the fuel injectors, oil change, no one can tell me what the problem is.
Sep 25, 2009 at 8:11 AM
  • 110,248 POSTS
Has the check engine light come on? Also, it sounds like the fuel pump may be going bad. Does it seem to happen more under a load?
Sep 26, 2009 at 4:57 PM
CHARITYH24
No, the only time I see the check engine light is when I start up the truck, but I have never seen it come on when I am driving down the road.
I don't haul anything in my truck it can happen in an incline or on a straight road.
I had asked someone to check the fuel filter, and he said the filter was fine, and when idling there was nothing wrong.
Someone said it could be the transmission, I don't know. I just didn't think I would have these problems as I have had the truck since it came off the truck.
Sep 29, 2009 at 12:33 AM
  • 110,248 POSTS
I would start with checking for vacuum leaks and check the fuel pressure.
Sep 29, 2009 at 12:55 AM
