2006 Dodge Dakota Engine Noise
2006 DODGE DAKOTA
58,000 MILES • V8 • 2WD • AUTOMATIC
JDMDAKOTA
  • 5 POSTS
My totally stock Dakota with a 4.7 auto makes a bizarre noise while cruising at speeds in the 40-50mph area. It only happens at that speed while cruising and if I hit the gas and it shifts down it stops. Also if I simply let go of the gas, the sound stops too. Its done it since I bought it and during this time it hasnt changed at all. It like a whistle almost, but its not really high pitched. Its coming from the engine compartment area.
Oct 13, 2009 at 8:02 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Is it that speed or a certain RPM? If it is speed and you are sure it is from the front end, I would say check the front wheel bearings.
Check the RPM's when it happens, and see if you can get it to make that noise at a different speed at the same RPM.
Oct 15, 2009 at 8:51 PM
JDMDAKOTA
  • 5 POSTS
Well I don't think it would be a wheel bearing because when I stomp on the gas and it shifts the noise goes away even if I still am in that 40-50 mph range. It happens when it's at a lower rpm like in the 1000-1500 range.
Oct 16, 2009 at 2:29 PM
  • 110,190 POSTS
It sounds like I said. Something internal in the trans. I wouldn't think it is something to worry about. I hate to say it, but this sounds like one of those problems that will require you to wait until it gets bad enough to find.
Oct 16, 2009 at 3:07 PM
JDMDAKOTA
  • 5 POSTS
But if it is the trans, wouldnt it make the noise if I was going down a hill or something because the RPMs are still in that area. Im pretty sure that by the time I reach the 40-50mph area I am in the highest gear, which would be 5th so I would think that going down a hill slowly in 5th with the same RPMs would do it too??
Oct 16, 2009 at 7:34 PM
  • 110,190 POSTS
Without hearing it, it is hard for me. However, if you think about it, there wouldn't be as much pressure on the trans.
Oct 16, 2009 at 11:23 PM
