Vent Question
LVBBRND
  • 2002 DODGE DAKOTA
Brakes problem
2002 Dodge Dakota V8 Two Wheel Drive Automatic
The air blows out the defrost and one vent and the floor why?
Thursday, July 29th, 2010 AT 8:51 AM
  • 109,755 POSTS
You have a vacuum leak. The air flow is directed by doors in the HVAC system. The doors are actuated by engine vacuum through small plastic hoses. If there is a leak, this is what happens.
Check under the dash for broken or disconnected vacuum hoses. If you are lucky, with the engine running, you may hear a hissing. Also, if you find nothing under the dash, check under the hood. That is where the vacuum comes from.
Sunday, August 15th, 2010 AT 11:15 PM
