2001 Dodge Dakota p0601 dtc
2001 DODGE DAKOTA
63,000 MILES • V8 • 4WD • AUTOMATIC
BOB1
My 2002 dakota recently had the engine light come on. when i checked the code to see what it was it said p0601 internal controller failure. i checked the tips in the scanner and it said to clear the code and see if it comes back on if it does it is probably the pcm. it did come back on same code but the truck runs fine it shows no sign of a problem what should i do?
Aug 20, 2008 at 8:38 AM
ALIUSV2
  • 9 POSTS
This is an internal PCM fault code. Sometimes it is just the rattle and shake of every day use that sets the code..especially if there are weak connections or solder joints. Now I've checked with STAR online and it says the same thing...replace the PCM. I don't know what more to tell ya.
Aug 22, 2008 at 2:33 PM
BOB1
I guess I'll drive it for a while and see what happens
Aug 23, 2008 at 6:12 AM
