2000 Dodge Dakota Fan
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
BREWINGTON
Electric fan will not come home, have checked fuses and relays and still not luck. considering bypassing. any suggestions
Jul 19, 2008 at 12:10 PM
OBXAUTOMEDIC
  • 3,719 POSTS
[quote:d028c065d9="brewington"]Engine Cooling problem
2000 Dodge Dakota 6 cyl Two Wheel Drive Automatic 150000 miles
Electric fan will not come home, have checked fuses and relays and still not luck. considering bypassing. any suggestions[/quote:d028c065d9]
Did you jump the relay to see if fan come on?
To jump....
Using test light find all power sockets make note of them. Then take a jumper wire stick in one of the power sockets then stick the other end of jumper in the sockets that are not powered. If fan is good should turn on.
If have doubts run wires straight from battery to fan. If still doesn't turn on most likely you have a bad fan.
Jul 19, 2008 at 2:12 PM
