2000 Dodge Dakota
MARGARITA
  • 2000 DODGE DAKOTA
  • V8
  • 178,000 MILES
I had the check engine come on and the code is p0455 where is it and how can I fix and is it expensive.
Saturday, May 17th, 2008 AT 12:57 PM
MASTERTECHTIM
  • 4,750 POSTS
This code can be caused by a bunch of things but its most likely a purge flow sensor and is located near the charcoal canister under the hood. Let us know if you have any more troubles
Saturday, May 17th, 2008 AT 1:35 PM
BMRFIXIT
  • 19,053 POSTS
May I add that you should check the gas cap
we found 80% was solved by checking and or replacing the gas cap
check for a gas leak too
Saturday, May 17th, 2008 AT 5:02 PM
