Depending on the manufacturer of the sensor, there will either be a thin plastic rib on the end that is designed to wear off or you must install a paper spacer on the end which will slide off when the engine starts. Those are designed to set the proper air gap. If you're installing a used sensor that had a rib, it must be sliced off, then the paper spacer must be used. If the new sensor didn't come with the spacer already stuck to the end, they are available from the dealership parts department.
caradiodoc
Mar 18, 2010 at 3:53 AM
