1998 Dodge Dakota I think my engine blew
220,000 MILES • V8 • 4WD • MANUAL
EREGER
My truck was acting strangley for about one month. Previous to that it had been burning more oil than usual for over a year. About one month ago, the check guauges light came on and the truck would not start. When I put oil in it and let it sit, it started again. Today, I was driving up a mountain pass, and the oil guage dropped suddenly to 0 and the check guages light came on. It stalled at the offramp. I had a mechanic look at it and they said it would be fine. Well, it wasn't. I drove back down the pass and it started making grinding noises. It would not engage into gear properly and took quite awhile to do so. Then it popped and smoke started coming out. Is this from too much oil? The problem is where I live, oil freezes overnight a lot. When you go to read the dipstick, it doesn'e read properly. I checked the oil after the first stall, and it looked too full. What could have happened? How much would it cost to repair?
Feb 5, 2010 at 12:24 PM
  • 110,248 POSTS
Where did the smoke come from, under the hood or the exhaust? Also, was there a knocking or ticking coming from the engine? Finally, too much oil isn't good, but it won't cause the engine to blow up. When you check the oil, does it appear to have any coolant mixed with it?
Feb 6, 2010 at 11:00 AM
EREGER
Thanks! The smoke came from the engine, there is a knocking coming from the engine, and there is no coolant in the oil. It has 220,000 miles on it, guess it was ready to go. I was offered to put a used engine in for $1500. It isn't worth that much. Plus I heard used engines aren't good to go with.
Feb 6, 2010 at 1:02 PM
